Turning innov8 into a modem
4 replies · 7,895 views · Started 10 January 2009
Can recommend some software that can turn the innov8 into a modem so that iPod Touch connect via bbom thru the innov8 ?
Hi. Check out either of the follwing apps. I'm not allowed to post url's apparently, so you'll have to decipher them 😊
three double-u's-walkinghotspot dot com
joikushop dot com (look for their product "JoikuSpot"😉
Gaco wrote:Hi. Check out either of the follwing apps. I'm not allowed to post url's apparently, so you'll have to decipher them 😊
Thanks.
But which one is more reliable in your opinion ? WalkingHotSpot OR JoikuSpot ?
thanks for the help. i too need this kind very desparately. willl try and let you all know how it is working.
havent used WalkingHotpsot but i did go thru the motions of trying JoikuSpot.
You'lll have to buy the premium version as the Light (free) one is not Samsung signed. The software will install and it will allow devices to connect to it as a Hotspot but it want let that device get access to the internet via the packet data connection (3G/Edge/GPRS)
i e-mailed the support people who sent me a two day free trial of the premium version and that worked a treat with my netbook. I then found a guide to connect the netbook via bluetooth and didnt need the JoikuSpot!
HTH
