The packetvideo encoding tools is out!!!!
6 replies · 2,675 views · Started 23 February 2003
Hello guys
Just a few words to tell you that the PacketVideo Suite for encoding videos is out now on the www.packetvideo.com site for a 60 days trial. Just go under the tools menu, fill your name..... and you can download it.
I found that there is some problems with the download page, so in case it doesn't work (if you're redirected to the main page) you can put this adress: http://author:[email protected]/authord/bin.asp
See you
gregi88
The Tools is Good and Powerful !!!!!!!
The Good thing is that the picture and Audio is at the same pace !!!!!!
The bad thing is that the producer did not allow us to use the AAC Function to change the Audio to 32.00kbps , 22.05khz Stereo !!!!!!
With only GSM-amr Audio ~ the audio is very poor !!!!!!!!!!
Guys is there a way to make the picture and Audio same pace with better sound then 16kbps ??? its come with a shsssss... sound !!
agree wif u sky,but i think maybe we can reconvert it usin mpegableX4 wif beta sound.hopefully it works.enjoy this great fone.
Pv is Good ! compression very powerful but the audio cannot make it !
:evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil:
