What is the Latest Nokia E90 Firmware?
3 replies · 11,432 views · Started 11 January 2009
Hi - just wanted to know IF theres a new Firmware Update coming out for The Nokia E90 ? what is the latest version? 🙄
Many Thanks
I read that they changed a lot about the security of the E90.
I have a lot of apps on my E90 and using hellocarbide for it (to get rid of the certificate prompts) but I want to be sure if it still works after upgrading to v300 because I don't want to lose apps. It is finally perfect like it is at the moment.
Does someone know it doesn't affect that?
DON'T UPGRADE TO 300.34.84 if you like having those apps.... 😉 The newer version of almost all firmwares kills the hacks. The E90 is especially hard to hack after that.
