Heyy i am living in Canada and i would like to know if i would be charged for using the Maps in my phone while i am sitting at home... and is there a option to connect to my Wi-Fi to view the maps plz reply
About Nokia N96 GPS
Any connection that uses Wifi would not be charged on your bill.
best way to check this is remove sim card and start fone without it in, if you try connecting it and it works without your sim you know it doesnt use any data allowence
thanxxxxxxxxxxx
gps will not accrue any charges, now if you add A-gps which uses network then you will accrue charges. it is also possible to have your maps preloaded on your phone, you can design the route and use maps independent of internet connection. hope this helps.
