At 9pm every night, my E71 beeps and displays "Notification not Supported", then goes back to normal.
I've checked nothing is running and the usual reboot etc.
Anyone else get this?
cheers
Gus
cheers
Gus
I get this as well, exactly the same.
Did you ever find out what was causing it as it's starting to bug me?
No, still no idea.
It's annoying but doesn't cause any issue. Just a pain to hear a beep every single 9PM!
On the off chance that somebody, somewhere is sending you a message at 21:00 hours, do you have another handset to put the SIM into?
Good thinking. will try tonight.
thanks.
What network is your phone on?
o2
