Nokia have just updated my UK E71 to firmware version 200.21.118. The first obvious change is the inclusion of MyNokia, a sort of gateway to Nokia services.
Does anyone know of any other changes?
Changelog thanks to MMAS, and GerryMoth for the heads up.
New functionalities in MCU SW version 200.21.118:
- Internet Radio application
- My Nokia application
- 3G power reduction for applications using keep-alive style messaging
- User experience improvements:
- Easy Dialing support for Simplified Chinese language
- Device Lock improvement: Open device lock with LSK + Fn-keys
- One key input method switch for China language
- �Mute� option in Right Soft Key when wired headset / hands free is connected
- �Loudspeaker� option in Right Soft Key immediately when phone call is started
- Enlarge characters in Chr-table
- NTLM v1 and v2 support for Intranet Browsing
- New black and red themes
Changes/improvements made to MCU SW version 200.21.118:
General
- Time zones updated
- Improvements to localization
- Localization fixes
- Missing localizations added
- Operator name database updated
- Startup Settings updated
- Certificates updated
- Security updates
- Stability and functionality improvements
- Barcode reader icon changed from 1D icon to 2D icon
- Windows DRM keys are not lost during NSU update from 110.07.127
Qwerty keyboard
- Keyboard mapping corrections
Browser
- Flash Lite improvements
Connectivity
- WLAN stability improvements
- EAP-FAST/TLS stability improved
- WLAN roaming functionality improved
- BT IOP and Dial-up stability improvements
Maps
- Several stability and functionality improvement
Messaging
- Performance improvement
Quickoffice
- Several stability and functionality improvements
VOIP / SIP
- Many stability and functionality improvements
Email
- Mail for Exchange upgraded from version 2.5.5 to 2.7.22
- Improved functionality when sending email via SSL/TLS SMTP server
Mobile dictionary
- Stability improvements
- Improvement for installed languages. Installed language can be removed.
Camera
- Camera image improvements & slow capture correction with certain HW�s
Music player
- General functionality and stability improvements
Java
- Update for CLDC-HI (Sun 1.1.1s Java VM)
Device encryption
- Device encryption functionality and stability improvements
Switch application
- Application updates and stability improvements
Great, another update that NAM 0569371 won't get 😡
I hope Nokia proves me wrong.
Not looking forward to reinstalling everything again!! My E71 has always run pretty smooth, may just leave it, unless there are any big improvements.
I have a E71-1, RM-346, Product Code: 0569132
Anyone have any idea when SW version 200.21.118 will be available via the nokia software updater application? Just wondering if anyone knows....
As a new E71 owner and first time Symbian owner, how do I check my firmware version?
Thanks in advance.
Dial *#0000#
You could also use teh software updater.
Shows current version and the latest version for your E71 model
Peter
