As the title says... Is it possible somehow (maybe with some application) to do a combination of keys for copy/paste text like we have on computers?
Keyboard Copy / Paste ?
you can do it with a gesture on the touchscreen
once you select the text you want to copy, the copy command can be invoked by doing a big mirrored L .. the phone will pop up an acknowledgement saying 'copied'
Describing the paste gesture is a bit more tricky :con?
It's a mirrored curvy 'E' ... oh wait..
try this link ... you can to delete the spaces, since this place doesn't let me post links..
my-symbian.com / forum / viewtopic.php?t=29274
Yes I know abou the gesture copy - paste, It's just that the paste part doesn't always work, you have to be pretty precise and I don't use handwriting anyway, I have it disabled. That's why I was looking for a keyboard solution. Maybe there's some application that can set some global hotkey for copy and paste
