Yeah, it's been the official release version for nearly a month now Steve... but hey, keep the news coming, it's nice to see reminders now and then, even if for poor you, it's only indicating things now.
On a somewhat different note, but related...
Advice for any users wanting to run PC Suite on the Windows 7 Beta...
This CAN be done, but you need to get it right first time, as you only get ONE stab at it...
Download the full installation package to your Desktop in Windows 7...
RIGHT click on the installer, and choose "Troubleshoot Compatibility" (the great new 'fix' tool that W7 contains).
As you progress through the wizard, choose the options for "This ran in a previous version of Windows" AND the one for "this application requires additional permissions". Then, when asked what version of Windows, choose Vista, as this should be fine.
Once the Troubleshooter has worked it's magic, the Installer should self-start.
Finish/close off the Troubleshooter if so, by saying the settings worked, when asked.
ADDITIONALLY, once actually installed, you might get more stable results if you close down PC Suite, then locate it's Launcher in the Start Menu, right click on it, and run the very same Troubleshooter for the Launcher, as you just did for the Installer - to set it up with the same options.
Then, click to Launch, and it should work fine.
THE BIG ISSUE is that if you download the installer, and first run it/click on it, in a normal way, and PC Suite tells you it is not for that version of Windows, then it is TOO LATE is seems for many, to then try again and run in Compatibility mode.
You MUST run the Compatibility Troubleshooter on the installer file the very first time, do NOT accidentally try it the normal way first...
Hope this helps everyone.
If you download the Software Updater installer, or the Map Loader application etc too, apply the very same process to these too - both the installers, AND the Launchers once installed.
If you do, they should all work flawlessly - they do for me, even on the 64 Bit version of Windows 7 - even to the tune of having carried out a full firmware update in Windows 7 - though not one for the faint-hearted just in case *lol*
