Nss error, plz help
1 replies · 13,331 views · Started 15 January 2009
Hi everyone!
i have a vodafone uk n73, today i downloaded and installed the latest v. of nemesis service suite, and i followed the instruction as many websites explains to change the product code..
the problem is that when i go for "scan" nss reports me an error on the taskbar (down left side) ...:con?
what can i do?
tnx
Hi there,
you dont need to press the 'Scan' button, look further to the right of the same window and look for the 'Read' button, this should then display the Product Code that is currently on your phone, once it is displayed, you can then edit it (change for the product code you want). dont forget to tick the ENABLE box, then click on 'Write'.
I hope thats clear enuff for you 😊
Regards
Markkyboy
