Using E71 as Bluetooth HID
0 replies · 4,310 views · Started 16 January 2009
Does anybody know if there exists currently an app that would allow using the E71 as a Bluetooth HID? that is, allowing you to use it as a bluetooth "keyboard" to control a pc with it... it has to be over Bluetooth HID and not programs that use a custom client on the pc as I use OS X and Linux, not windows.....
From what I see of the bluetooth functioning this should be possible technically, I just want to know if there's a program out there that does it, or if I'm going to be forced to code my own (not easy at all).
Thanks!
