Nokia India release a salvo of free 5800 applications
9 replies · 5,556 views · Started 16 January 2009
Nokia India has kindly released half a dozen free applications for their new 5800 XpressMusic, good to see this getting off to a fast start in most markets. The applications (three utilities, three games) are: SMS Timer, Smart Guard, Marble Maze, Wave Secure, Touch Card Match and Touch Maneuver. Well worth a download for any 5800 owners out there.
It gives expired certificate error. even the installation settings are proper and all, yet all the same. I even tried changing date in vain!!!
Smart Guard seems to work jsut fine except one problem. it still displays one of the hidden files. like if you hide a folder containing 10 images/videos, in real player or gallery you will see atleast one of them,though the remaining 9 are hidden. wierd bug.
On my nokia 5800 i can use only sms timer only as smart gaurd is not working it keep saying you need to have a indian sim to use that program. did any one know how to use it.
thanks
I have now downloaded every thing possible for the 5800 and none of the games are worth playing as far as I'm concerned. Anything that used the stylus has a time lag that completely messes up time-sensitive games. Just because it has a touch screen doesn't mean that touch has to be used for everything. There are three hardware buttons - use those for game control, and touch to bring up the menu (and keyboard, while we're at it, so we can run more apps properly!)
Hi, try restarting ur phone after hiding the folders and files, it should not show after restart.
Hi Friends I downloaded This Software But Its Working Only In INDIA....Not For other Country s..
Thanking For Share..
smart guard got expired and i cant reach my hidden files
