the program celesta-mystyle is supposed to be able to send flash sms.
dont really know much about flash sms, but does it work on all phones. is flash sms dependent on network also?
Think it work on most phones.... its been around for ages now!
Nope network independant! (Well cant see y it would be network dependant!)
hello.
i have been using emessaging and i cant seem to make the flash sms work too. it supposed to work too w/ the said program. tried sending a couple of messages thru diff models but none of them seemed to work. it all appeared as a normal "message revceived". Help. If there are any users there of emsessaging.
i hope that theres no confusion between flash message & blinking sms??
as u know flash messages open directly on the scree & blinking sms ,when opened blink...
ive got emessaging & its working perfectly, but ur right it does not work on all phones. its worked with an 8250 / 8210 / 8850 / 8890 / 6210 / 3310 / 3330
but yes i have noticed a small thing that makes me think that its network dependant. when i sent a blinking sms to a 3310 it worked perfect & right after that i sent another one & it did not work.
maybe network overload or something.
try it late in th night,when the load is less.
HyPeR(gaurav)
to continue on the matter, did you guys get mystyle or extended messaging? emessaging is cheaper but mystyle has some other features. im gonna get either one soon so a little feedback would be cool.
<TABLE BORDER=0 ALIGN=CENTER WIDTH=85%><TR><TD><font size=-1>Quote</font><HR></TD></TR><TR><TD><FONT SIZE=-1><BLOCKQUOTE>
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR></TD></TR></TABLE>
umm... I've looked in both of the programs and I prefer eMesseging... The only advantage that mstyle has is that you can put a logo in 9210 without sending a SMS...
I believe that eMesseging is easier to use...
If mStyle was cheaper... maybe I would buy it... but...
Anyway... that's only my opinion of course...
i already registered for emessaging and its great. mystyle is way too expensive for a program such as this. emessaging works perfectly fine w/ me. i have to agree that the only clear advantage of mystyle (besides the skins) is that you can directly send a logo to the 9210 without using sms.
Currently i have 300+ logos in my 64MBmemory card. ![]()
when i downloaded the demo version of my-style i thought it was a bit complicated & definately expensive. i prefer emessagng & have regestered it now.
by the was could you please send me those 300 logos, please.
thanks
HyPeR(gaurav)
thanks
HyPeR(gaurav)
sure. i would love to send them to anyone. how do i send it to you? email?
