Phone: E71.
It has been a week since the last time I can view my images and videos that I took from my E71 camera, which automatically saved on the memory card.
I checked on Office-File Manager and choose memory card tab, then opened the images folder: All the images were there.
But somehow I cannot see it on the Gallery application. It also 'hangs' after trying to do some settings.
Tried to update to the latest firmware just now, and it still can't read all images and videos from the memory card.
How do I fix this?
Anybody?
Or is there any third party gallery application that I can use on my E71 to organize and view my images and videos?
OK. It's been a while.
However, I just though it might help other users (stupid ones like me).
I reformat my memory card and it all worked great.
The problem was caused by the memory card and had nothing to do with the software.
Don't forget to back-up before you reformat your memory card, as it will erase all your data and everything in it (including applications and themes).
I am facing the same problem with my nokia N96. I dropped my cell from a very low height, which i have been doing in the past aswell, but this time my real player application was running. Now my cell is not showing the music files and the photos. Though i checked the memory card on my pc...all the files are there! :S
I'l try the formatting thing. Hope it works! 😊
Here is a similar thread . Maybe some usefull info included ?
http://www.allaboutsymbian.com/forum//forum/thread/92278/
However , after a fysical invoked disfunction , it might be different , like not being a software issue .
😊 Regards jApi NL
