nokia n81 8gb help
7 replies · 7,599 views · Started 19 January 2009
hi,
this is my first post and already i seem dumb !
i need to turn on my bluetooth but my screen is broke (gone black with a white line down the middle). i can still turn the phone on but what i need to do is either bluetooth my contacts over to my pc or copy to sim...but as i cant see the screen and remember the menus i need help
anyone ?....screen shots would be very helpful if anyone has any.
cheers
Paul
install pc suite and connect your phone via usb and back up your phone that way. probably the easiest way i would imagine.
i take it you are clicking the ok button on the phone after connecting as it brings up a menu asking if you are using pc suite, media player, data storage etc. pc suite is usually top of the list and default selected. So after connecting the usb, press the button on the phone as if selecting pc suite.
i'll give it a go, but like i say i cannot see anything on my screen, i hear the start-up tone when i turn it on but i just have a blank screen.......
i'm trying the cable option and for some reason i can now explore my phone through my computer....can i get the contacts from here ?
...i swear i saved my contacts to sim but they dont seem working on the back-up phone o2 gave me and i really need some of them.
Paul
well go to the memory card bit (through the PC suite) choose the 'others' folders in there will be a contacts folder and in that will be all the contacts from the last back up (if you ever did a back up) if not i dont no what to sugest as nearly everyones nokia Nseries phone will be set up diferently (menus and all) so did you hot key the contacts at all? say on the left key or at the top on the standby screen? a lil more info and maybe i could help
i kno this has nothing to do wiv wat ure on about but i have a nokia n81 8gb and its always worked great i love it but the other day it just totally freezed up meaning it turns on and comes on to menu screen but wen i try to go in to any thing the buttons will not work any of them even the number buttons. its really frustating and ive looked on the internet for solutions and carnt find any
please help if u can 😊
