Tipard DVD Ripper Pack is actually the combination of Tipard DVD Ripper and Tipard Video Converter. With the DVD rip software and video converter, you can convert DVD and any video to all the video and audio formats for all the portable players.
Input Formats: DVD, IFO folder and MPG, MPEG, MPEG2, VOB, MP4, M4V, RM, RMVB, WMV, ASF, TS, MKV, AVI, 3GP, FLV, MPV, MOD, TOD, MP3, MP2, AAC, AC3, WAV, MID, MIDI, WMA, M4A, RA, RAM ..
Output Formats: MP4, H.264, AVI, MP3, WMV, WMA, FLV, MKV, MPEG-1, MPEG-2, 3GP, 3GPP, VOB, DivX, Mov, RM, RMVB, M4A, AAC, WAV, OGG, RA.
Key Functions:
1. Set the video effects, audio track and subtitle
This pack allows you to adjust the brightness, contrast and saturation of video and volume of the audio by drag and click the adjustment bar. It also allows you to choose the audio track and subtitle to fit for your needs.
2. Cut any episodes from your DVD or video
Click �Trim� to capture any time-length video clips. You can set the �Start Time� and �End Time� to set the time of the clip or you can directly drag the slide bar to the accurate position.
3. Crop the video play region
By using the �Crop� function to crop off the black edges around video and adjust the video play region. It allows you to set the Crop Mode and Zoom Mode to exactly fit for your player.
4. Capture your favorite pictures and merge your wanted contents into one file
This Ripper Pack provides you to capture your favorite pictures when you preview DVD or video. You can join your DVD chapters or video pieces into one file for you to enjoy successively.
