as the E71 is my first GPS-Phone, I am a bit surprised that I cannot find a connection between my adressbook and NokiaMaps / GoogleMaps. When a contact is shown, there should be a feature like "show adress on map" or "show route to adress".
Do you know of an application that has that feature?
Some of the third party Sat Nav program have this feature (but only from within the sat nav application. This is something that is on the road map to be added to Nokia Maps I believe (though whether that ever makes it open to the E71 is open to debate)....
I find the easiest way to deal with this is to copy and paste the post code across. (Ctrl+C / Ctrl+V). Not ideal, but you generally only need to do it once,
