Download ArabicSMS
29 replies · 7,663 views · Started 24 February 2003
copy everything in the first file(arabicsms) to C \ SYSTEM\ APPS \ ARABICSMS .. you have to create a new file called arabicsms
copy everything in the second file(cu) to C \ SYSTEM \ FONTS .. even here you have to create a new folder called FONTS
Thanks DmX
Great JOB
Now all I need is a localizer and I'll be all set to go 😊
So it is supposed to work after you just copy the files, nothing else??
One more Q:
Do I need to unzip them first on the PC then move them the phone?
😮ops: 😮ops:
[quote="Link"]So it is supposed to work after you just copy the files, nothing else??
One more Q:
😮ops: 😮ops:[/quote]
yes unzip them first
[quote="hazem"]but where can i download these files from?[/quote]
you have to register to download stuff
i have visited yahoo page
and i am register it user there
but the thing that i didnt find a file for arabic sms there
[quote="coolfighter"]i have visited yahoo page
but the thing that i didnt find a file for arabic sms there[/quote]
you have to register in AAS 😉
anywayz thanks for reminding me to add it to my group
By the Way ... i Got this .SIS file from Another Forum..some unoffical programmer made it.... it opens the Arabic SMS from the Same inbox ... but some incomplete stuff in it as :
1.the keybord does'nt support Arabic layout .. and it has some of it's buttons as clear Hollow Blocks ...
2.Slow's Down the phone preformance it lags when u command or click it to go to something ... and the phones Font is even changed!!
P.S : by the way read the info that appears in installation .. for uninstalling you have to check the info while installing the program ...
this is a Beta or incomplete version designed by a programmer
i hope some one would solve the problems
Hello All
Where can I find these files you guys talking about??
I'm registered to the group but found no file related to Arabic SMS under any subject, can some one please e-mail them to me
[email protected]
Thanks.
[quote="nim_181"]By the Way ... i Got this .SIS file from Another Forum..some unoffical programmer made it.... it opens the Arabic SMS from the Same inbox ... but some incomplete stuff in it as :
i hope some one would solve the problems[/quote]
help...please...i want to uninstall it..but i can't...i did everything that it says...
can anyone tell me how do i master reset...cause everytime i try to..it tells me i have to put the dvice lock number...which i have no clue what it is...( i didn't put it in the first place)....HELP!!!!
I think this is how you uninstall
1- Remove memory stick
2- Turn the phone off, then back on
3- Put back the memory stick
4- Uninstall normally
:robot:
Hello again
registered to AAS and downloaded files, but couldn't find the c/system/app folders on my P800 using My P800 explorer that is installed on my PC, I have checked my mobile to get to drive C or D with no luck, all I get is Video, Audio, Imege, Document and Other.
Please help me installing files :cry: :cry: :cry:
[quote="penta_a"]Hello again
Please help me installing files :cry: :cry: :cry:[/quote]
My friend try to download File manager and connect your P800 to your PC and you will see your P800 C & D drives on your PC
i have visited the yahoo p800group, i have registered an ID
but i havent found the the arabicsms
Ok guys here is what i have done:
reinstalled PC Suite for P800 again to my PC (automatically and manually), and this what I got installed:
1- Backup and restore
2- Install Software
3- Download language
4- Syncornization
5- Sync station setting
and got the P800 on my desktop
searched for this "File manager" thing and couldn't find it any where.
the P800 on the desktop doesn't give any option to creat or see system files.
Can some one please tell me where is the trick and how to use it so I can install the Arabic SMS support files??
Thanks for your reply.
I have got an email from psiloc.com that they will be releasing a full Arabic localizer for the P800 within one week!
I cannot wait!
:angel: :angel: :angel: :angel: :angel: :angel: :angel: :angel:
[quote="penta_a"]Ok guys here is what i have done:
2- Install Software
4- Syncornization
Thanks for your reply.[/quote]
OK my friend this link I made for a friend to get P800 applications and the PC File manager is one of them.
The site link:
http://foruksa.0catch.com
The PC File Manger can be downloaded it will be under the house picture
[quote="al_a"]I have got an email from psiloc.com that they will be releasing a full Arabic localizer for the P800 within one week!
I cannot wait!
:angel: :angel: :angel: :angel: :angel: :angel: :angel: :angel:[/quote]
will it be for FREE ?? :-?
Q1. Where can I get the file manager from? I can't see the C of my P800.
Q2. Is there any arabic language support that will be available to the P800?
:-? :roll: :-? :roll: :-? :roll:
[quote="ahmedmuh"]Q1. Where can I get the file manager from? I can't see the C of my P800.
:-? :roll: :-? :roll: :-? :roll:[/quote]
Get it from your brother, I already e-mailed it to him... 😉
[quote="Link"][quote="al_a"]I have got an email from psiloc.com that they will be releasing a full Arabic localizer for the P800 within one week!
I cannot wait!
will it be for FREE ?? :-?[/quote]
Not it won't be free 😞
