[N79] remote drives always connected?
0 replies · 3,389 views · Started 23 January 2009
i set up my server and configured my phone and...the disk work fine!
then I want to disconnect it because i will need this function only few times. some seconds after disconnection the phone prompt for choosing an access point: it was the disk that try to reconnect. it continue ask me for connection until I connect it again. the only way to stop this is deleting the remote disk configuration. is like the phone is set to keep the disk "always connected", is it normal?!?!
Nokia N79
Firmware 11.049
if you want to try on your send me a message if you need a drive to test
