gallery still not as good as it should be N95-
1 replies · 2,046 views · Started 24 January 2009
Are newer N series phones the same? As in on my n95 8gb I can use allbums but items dont get "put" there they simply appear in the gallery and the album.
It would be better if it worked like the video gallery where you can actually place them into folders and even better if you could protect folders etc.
Come on nokia..
indeed, the gallery is beside the lack of folders really slow
i have installed the GREAT image exchange application from nokia (beta though) to use it instead of the standard gallery http://betalabs.nokia.com/betas/view/nokia-image-exchange
it is very fast, zooms way faster and smoother and supports the accelerometer, its worth a try
as for now, videos are unfortunately not shown within the app
