Had my N85 since the beginning of December, and I have to agree with the many people that it feels fragile (the sooner this level of tech gets commoditised and ruggedised for the normobs, the better). My main concern is the screen, I already have several marks in the glossy coating, I would use my phone alot more confidently if i didn't think i would make the situation worse everytime I use it.
So i need some recommendations on two things
I screen polish/scratch removal kit
and a screen protector/case (there seems to be a huge grey market and it seems difficult to decipher which products (and vendors) are reputable
really appreciate any help given
twinpeaked
get screen protectors off ebay i got 4 for �2.99 inc P+P they stick on the screen (buy some for the next brand new phone)
as for the scratches already well i dono i wouldn't bother to remove them unless you was going to buy a new fascia instead then just get the screen protector on there from the word go!
Thank you for your reply, currently snooping around for screen protectors
I have decided to go for a new fascia and start afresh, I didn't realise it was removable and presume that this was "the screen". Was able to easily remove it and confident about the job
The only problem is I'm having trouble finding a fascia online, are they available? or is the phone too new for this part to be available?
aso what price should I consider good value?
I really appreciate any responses
