Does anyone know where these are in London? And if so whether they can do it on the spot? I bought my handset SIM free hence I can't really hassle my operator....
Cheers for any help
Cheers for any help
Have a look at this:
http://www.nokia.co.uk/Products/recyclingSearch.asp
Select London from the drop down, and all the NSC will be listed.
Call to see if they have what you want 😃
Cheers
En Croute
I think you can also look from www.nokia.com
from support
Does anyone know of any NSC in London that has higher firmware than 3.16? I cannot be bothered to phone round all 25 or so listed in the aformentioned Nokia webpage
Try the Carphone warehouse on Oxford Street.....its located near the Tottemham Court Road end.......they should have 4.39 and usually there is a 2/3 hour turn around!!!!
Carphone warehouse in Baker St (or just round the corner) have 4.39, and have a 4 hour turnaround.
