I find that their customer support is not the greatest as well as their advertisement about the 30-money back guarantee is just a ridiculous joke.
Cheung Yuen Wong
Posted On: Feb 06, 2009 12:41 PM
First of all thank you for a great product.That said I'm still a bit dissapointed in the latest version of your software.
Indeed it does mostly of what it states it does.
However when it comes to the viewing of .zip files it does not do that.
One of the issues I'm having is that I have a .zip file which has a folder in it.
In this folder again there are two folders and a multiple of files.
(What I basically are saying here is that you have one folder in which there are subfolders along with some files).
When trying to view the files it won't simply show up, just two of the files and none of the folders shows up.
I've included two screenshots regarding this case.
First one is from the filemanager within QuickOffice
Second one is from the filemager X-plore
As you can see from the second picture X-plore displays all of the files,
while QuickOffice don't.
Another thing that bothers me is that I don't like the GUI of the new version of your software. (Personally I think that the version 5 had a better GUI)
Icons that expand itself and so on.
It would be nice if the transition hadn't taken so long though.
As it is now it simply becomes a bother when trying to browse through the folders on my phone, taking away the focus of what I'm trying to e.g. look for.
I therefore want to claim the use of your 30-days Guarantee, as your product currently are not doing what it should in regards to viewing of .zip files.
Thank you in advance.
P.S. I'll defintely will buy your software when I get the N97
(and then probably will get used to fancy icons expanding)
but as for now version 5.0x works great for my use on my N82
Larry
Posted On: Feb 06, 2009 04:03 PM
Hello,
Thank you for your message.
Did you you create the .zip file, or was it created for you? If you did create the .zip file, what did you create the .zip file in? Would you mind sending me the .zip file so that I can test with it please.
Thank you,
Larry
Cheung Yuen Wong
Posted On: Feb 07, 2009 10:13 AM
Yes, I created the .zip file myself and I did it on my laptop running Windows XP.
As for the .zip file I tried sending it to you via the upload file option but I guess it's too large
to be uploaded.
The size of the .zip file is approximately 80 mb.
Larry
Posted On: Feb 18, 2009 04:08 PM
Thank you for your patience while I attempted to recreate the issue you have reported.
Luckily you were able to get screenshots of your file, unfortunately I have been unable to recreate the issue. I have reported it to our Engineers for further review.
We will report back to you once they have finished their investigation.
Regards,
Larry
Cheung Yuen Wong
Posted On: Feb 20, 2009 06:47 AM
Thank you for testing as I said earlier the file in which I tried to open was about 80Mb in size.
I have therefore now uploaded it to a filesharing host for you to download
http://www.megaupload.com/?d=BIB1LNA4
The folder structure in my memory card starts with E:\ and therefore the whole content with the folders is E:\A - Essential\ and so on.
That said there seems to be an update of the QuickOffice application, how do I retrieve that?
My current version is 6.0.263 while I find that there are versions that are 6.0.270.
I've found no way to conveniently upgrade the application purchased with you and I find it also strange that I would have to pay again to get an update of this version.
I thought that the reason to support the software was to get the following:
1. Customer support
2. Upgrade within the same version is easily downloaded
1. You have shown that to some extent, by trying to help me, that has still not helped me with the issue of not displaying the .zip file in which I submitted this ticket for.
2. There are no mentioning about the upgrades version of the software that is from 6.0.263 to version 6.0.270
Which such reasons for purchasing a software which fails to the expectation of the customer, I'd really rather used pirated version of your software than purchase it.
With other words I'm not satisfied with either your customer service nor the advertised 30-day Money Back guarantee.
As you can see from the conversation with the one at the support indeed he does try to help me, but unfortunately as a customer I'm really left down by the following 2 things.
1. When they advertise something such as 30 day money back gurantee, that guarantee has to kept. You can't simply just close a case because you couldn't get to see the problem.
2. Where's the option to update the software? Here I mean the option to upgrade to a new version within the same number e.g from 6.0.263 to version 6.0.270.
(Here my purchased applications from Lonely Cat Games was definitely worth my money, as well as the convenience of changing the license code when chaining my handset)
I really want to support QuickOffice but with such bad costumer support I'm not going to purchase any more software from them in the future.
I'd rather go and wait / find modified version of the software instead of supporting them.
