Hi.
Just a small, but annoying problem.
I need an application which will allow to rotate the picture on the phone and save it in the new state.
Built-in Gallery can rotate, but it doesn't save anything.
I found there is a Still Image Editor from Nokia, it installs just well, but then don't work. There should appear a new menu item in Gallery when you open an image menu � 'Edit', but there's nothing. A very few posts found through Google confirm there is such a problem with e51.
So, could you advise an image editor which will work on e51?
