Motorola S9 Bluetooth Headset & N95
1 replies · 5,499 views · Started 29 January 2009
Have been using this combination for some time now and it works brilliantly.
But for some reason (recently) the headset will not answer an incoming call or initiate an outgoing call from the call button on the headset, instead it varies the volume. If I accept the call by hitting the green button on the phone, the headset works away no problem.
I am not sure but I get the impression that the headset is not faulty, but for some reason the A2dp on the phone is gone funny. Have done the usual rebooted, re- paired the device etc.
Anybody have any ideas?
I've had issues like this on 3 totally separate Motorola S9s.
Have you ever used them down at the gym, whilst running, etc. and did you sweat ever so slightly?
The S9s have a chronic issue with not being able to handle small amounts of liquid, even though they're supposed to be waterproof.
Sadly, its likely to be the Motorolas at fault, not your phone.
