I have n95-4 8gb and I'd like to add Czech language into it.
The firmware version is 20.2.005.
As I found here I downloaded NSS to change the product code which I changed to EURO 2 then launched Nokia Software Updater.
The Updater didn't find any update.
Why it didn't find the 31.0.015 version? I also tried and changed product code to EURO 1 and EURO 3 with no success as well.
Any ideas?
Czech language for n95-4 NAM
i think your trying codes from n95- 8gb euro variant, which is the only n95 9GB to have v31 update and its firmware cant be put on n95-4
if you are plz change you code back to original before u brick your phone
all the different kinds of n95's have firmware built specific for it's model
n95-1 ,n95-2 ,n95-3 ,n95-4 all these have there own exclusive firmware and cant be put on each other
if you you used same product codes as listed from the 1st page below then don't use them they are not for your variant
http://www.allaboutsymbian.com/forum//forum/thread/58225/
Since the N95-4 is an American phone, it will support only the languages that are deemed necessary in American. As such, the N95-4 will never support Czech. You will need an N95-2 to be able to get Czech language since that is the European model.
