Hello everyone!
I'm having a slight problem with my N96. The phone came with firmware v11 and I updated to v12 the following day. When I bought it, I had about 32mb left in the C: drive.
Now I only have half that space left. The thing is, I only installed 2 small apps on C: (everything else goes to the mass memory) and I delete the web cache regularly.
Every time I install/open/use an app, I see the available space decreasing, even though I do my best not to use the c: drive.
From the memory report, I have around 2mb in sms, so that shouldn't be the cause either. Pictures and such are all saved on E: (mass memory). The memory report also says I have 55mb of "other files" in C:, of which I have no idea what/where they are.
Recently I managed to gain access to all protected files just to see if there was a logging program slowly filling up my memory in the sys folder or so. No such luck, but I noticed something else. According to activefile file manager (manufacturer version), I have 25mb of used space.
If that's the case, why do I only have 17mb free out of 82? Because 82-25 = 57, not 17.... And why does free space keep decreasing if the used space doesn't increase?
I'm puzzled by all this, and worried as well. If I don't find a solution to my problem, I'll eventually have to reformat due to lack of memory, which I really don't want to do. Can anyone shed me some light?
Thank you in advance!
