hey everyone,
using seleQ, i find on C:\101\Bin
a file called KXracer.dll which takes up a whooping 244kb.
does anyone know anything about this? is it safe to delete the whole folder?
thanks in advance!
hey everyone,
thanks in advance!
If you have an application/game installed called something like racer, then I wouldn't delete it. I had this folder once after installing something, i can't remember what it was, but I think that it is a folder created by the programmers to put their own custom files so that they stay out of the way, it should be removed when you uninstall the related program.
It's should be safe to remove it. You need to do a proper uninstall of the appl that run it.
My c drive does not contain this folder. Should be save to remove.
As far as I remember "C:\101" and its subdirs contains the games for the MagicGameStation.
