Ok what is the code for a GSM Number in the fax templates?
ie. email = <sender_email>
tel = <sender_tel>
etc..
Anyone have any idea... i have tried almost everything i can think of but no luck!<font size=-1>[ This Message was edited by KayonLord on 2002-04-04 1640 ]</font>
Hi
I only use my mobile No so I leave the tel no blank in the my details thing in the telephone directory (sorry my noks in french so i dont know what its called in eng. ) and it picks up the GSM no and sticks it in the fax heading
youre right though just spent an hour messing around trying to get phone and mobile no to show up and cant
the only way i ve found to do it is to create a template for word or whatever the wordprosseseurs is called in the english nok
write the fax useing word template in word hen hit the send as fax option
that way you can send the heading you want but must admit its not very elegant as a solution
I will keep trying combinations in the fax model to see if its possible (got a 6 hr train trip ahead of me it will help pass the time)
just to save time what have you tried ?
this sort of thing should be quicker to work out in the emulateur but you need win NT to run that ....
Chris
So far only tried to one it should maybe be like most options with mobile or gsm in them.
You could put your GSM number in the fax field of your Contact card and put <sender_fax> in there? That should display the number correctly?
