Unable to synchronize N95 with Outlook
5 replies · 7,324 views · Started 02 February 2009
Dear fellows,
I have been successfully synchronizing my N95 with Outlook. But after upgrading the software to 30.0.015, I am unable to synchronize contacts, calender entries or anything with Outlook. Everytime, the synch is shown to have completed but I don't get anything in Outlook.
Any idea what to do?
Ejaz
A few more details please.
Are you on XP or Vista?
Are you using Outlook Express or Office Outlook?
What version of PC Suite are you using?
Dial *#0000# on your phone and give the details also here. In the meanwhile, when your phone is connected with pc sync, you can see the sync icon on the right hand side of system tray near clock, right click on sync icon and exit and then create new sync settings in Nokia PC Sync. Try to sync and check
Nokia PC Suite 6.81.13.0 which I got along with N95 on CD. I am using Windows XP. I have been synchronizing it with Microsoft Outlook (Part of Microsoft Office) not Outlook Express, when my phone had previous firmware. But now that I have 30.0.015 version, it can't be synchronized.
Please provide detailed information about the configurational steps to do on phone and MS Outlook.
While synchronizing, all the steps are proceeded normally, PC send request to phone which I accept, and the progress bar shows the completion of synchronization, but no contact is updated to MS Outlook.
I tried one way updating from phone to Outlok as well but it did not work either.
