Did you guys face the same problems??I cant receive any data by infra-red even when receiving data from another phone!!!!
My 7650 IR doesnt work...
works fine for me. i had a problem wit m router when i got mine flashed to 4.39 but then i got pc suite latest from nokia and its back to normal. download the file from the net and then try again. lemme know
What file??The new nokia pc suite??
Sometimes, my pc does make a connection with my phone.However it doesnt recognise that its a 7650!!!
[quote="thegreatwann"]Sometimes, my pc does make a connection with my phone.However it doesnt recognise that its a 7650!!![/quote]
that happens with me sometimes too, just cancel the link and try again, and it works fine.
when I had my 7650 I faced the same problem, after a while everything started to work fine. if you are mentioning problem with pcsuite, it occurs frequently. if your problem insists go and visit your service.
