Whatever I do, my video light will not come on. The LEDs flash for stills, but if I touch the lightbulb icon to remove the cross through, no extra light is switched on. Anyone else got this working ? F/w v11 in case it matters.
Video Light ?
OK, ignore me. It only comes on when recording. Which in itself seems like a bug, how else can you judge framing and exposure ?
well on mine it comes on recording for one second only then switch off whatever I try
even a hard reset did not solve the problem
The flash is working ok for stills though...
Any ideas on this one ?
bluestar wrote:well on mine it comes on recording for one second only then switch off whatever I tryeven a hard reset did not solve the problem
Same here...
