Update Google Maps app
19 replies · 14,814 views · Started 05 February 2009
I see Google have released a major update for Google Maps which includes the new Latitude friend locator functionality (optional of course!) : http://googlemobile.blogspot.com/2009/02/locate-your-friends-in-real-time-with.html
So I tried installing it from google.com/latitude, but it would install and gave the error message something like 'Cannot install Google Maps is built-in'.
So am I stuck waiting for an update from Samsung via Pc Studio? Or is there some way I can get around this?
streetdaddy wrote:I see Google have released a major update for Google Maps which includes the new Latitude friend locator functionality (optional of course!) : http://googlemobile.blogspot.com/2009/02/locate-your-friends-in-real-time-with.html
i need it too???!!!
Happened to me too and I didn�t find a way around it... i guess everything that came pre�nstalled at the ROM is protected from deleting, updating,... it sucks a little, not too much though.
no its not the end of the world... but this pre-installed apps is getting more annoying. No updates seem to be coming from Samsung via PC Studio 😞 I now have 2 apps that I want to update, and one is because it needs a bug fix...
hi guys i found a way to update google maps first you have to hack the phone after i can give you the file and you have to paste on c: drive that is it i also updated route66 i managed to install nokia maps and nokia's internet radio
bujar1 wrote:hi guys i found a way to update google maps first you have to hack the phone after i can give you the file and you have to paste on c: drive that is it i also updated route66 i managed to install nokia maps and nokia's internet radio
Can you elaborate on "hack the phone"?
I have the phone hacked, can you please tell me how to do this now?
srw985 wrote:I have the phone hacked, can you please tell me how to do this now?
hi you have to use helloox after hacking with x-plore file manager you can see the system folders i will upload the google maps somewere and all you have to do is override the files and after that you have updated you program to the latest one
bujar1 wrote:hi you have to use helloox after hacking with x-plore file manager you can see the system folders i will upload the google maps somewere and all you have to do is override the files and after that you have updated you program to the latest one
Look forward to the post, if you can post step by step instructions on this it will help lurkers and posters alike. Cheers 😊
How did you install Nokia Maps?
I have tried signing a certificate-free version even, but even that says "install base package first"
Micky! wrote:Where are you getting your Nokia Maps from? Are you using the Nokia Maps Updater?
tried the unsigned files from dotsis forums and the official nokia site
What? What you doing trying to install any files that need signing in the first place for Nokia Maps??
Dotsis is full of cracked, and warez, be careful my friend.
Have you downloaded, and installed Nokia Maps Updater on your PC?
EDIT - Ignore my comments above, i thought you were talking about a Nokia handset, sorry.
Micky! wrote:What? What you doing trying to install any files that need signing in the first place for Nokia Maps??
yup, thats the problem, official installer wont work because nokia block installation on non-nokia handsets. bit silly really cause if theyd let me install it theyd be making money on my subscription
Hi all, I managed to get it working by doing the following:
1. Download GoogleMaps.sisx, either from forums, or using your mobile phone and then transferring the file to the computer.
2. Download SISContents from http://symbiandev.cdtools.net/
3. Use SISContents to open GoogleMaps.sisx, and then extract the files somewhere. There should be 4 folders (c_private, private, resource, sys) and 1 file (Google_Maps.pkg).
4. Transfer the extracted files to your phone.
5. Using X-Plore, Modo, or Y-Browser (or any other file manager that can view all files), move the following folders (private, resource, sys) to C: (root). I did not copy Google_Maps.pkg and c_private.
6. Turn off and then turn on your phone. Google Maps should now be updated.
Hope it helps!
Note: After doing the above, I then tried to install Google Maps directly, but I'm still getting the component is built-in message. Anyone knows what file/setting to remove/change to stop having that message?
