When connecting to the internet should I be using WAP Services or Internet with my O2 Unlimted Web Bolt-on? I'm guessing the latter?
many thanks
many thanks
It shouldn't matter, but the Internet is better as there are less restrictions on that access point.
If you're using WiFi at home /work/wherever. You can add that to the Access Point Group 'Internet' (see settings) and it will use that when available too.
Thanks for that, much appreciated.
