twitter bandwidth
1 replies · 2,474 views · Started 05 February 2009
Im hopefully going to buy a 5800 next week when i can get to CPW but would like to use the phone with my current sim which is on the blyk network. from next month they will be giving me 15mb data free every month and i would like to know if this will be enough to use twitter on my phone while im out of wi-fi range?
Does anyone know the best twitter client is for 5800 that uses a minimal amount of data?
Also can the phone be setup so it uses wi-fi while in range and switches to GPRS otherwise?
thanks kuliand
I reckon your best bet might be the mobile twitter site or dabr.co.uk. I also think 15mb should be plenty for this, but there are a few Java client you could also check out (Twim for example).
