Trying to setup voicemail on my N95 8gb.
I have set the mailbox number. I get a message saying "Not enough memory to receive SIM messages. Delete some data first"
Any idea what this means.
Sounds like your phone memory might be full.
Try the following:-
Menu > Options > Memory details > Phone memory
See how much free memory you have on Phone memory.
[email protected] wrote:Sounds like your phone memory might be full.Try the following:-
51mb Memory in use
83mb Free memory
13mb Messages.
OK.
Let's check to see if you have any SIM messages on your SIM card:-
Menu > Messaging > Options > Sim messages
If you have some old Sim messages on there you should delete them.
Hope this helps!
[email protected] wrote:OK.Let's check to see if you have any SIM messages on your SIM card:-
Hope this helps!
Deleted the messages on the sim.
When I try to access voicemail it tells me my settings have been updated and to try again in 5 minutes. I then get a text message which I am told to delete.
Still can't access voicemail. I still get the same message.:con?
After opening the message and then deleting it you could try powering your phone off and then on.
Which service provider are you with (Vodafone, Orange, etc.)?
[email protected] wrote:After opening the message and then deleting it you could try powering your phone off and then on.
Tried that, makes no difference. I am using T-Mobile.
saabbhoy wrote:Tried that, makes no difference. I am using T-Mobile.
This may help you with T-Mobile voicemail:-
[email protected] wrote:This may help you with T-Mobile voicemail:-
Thanks for that, I had the wrong prefix before my number.
That's why I love internet forums.:icon14::icon14::icon14:
Glad you got it sorted. 😊
