N85 Wifi problem
1 replies · 4,838 views · Started 07 February 2009
I wan to access to internet using my home wireless connection but this problem occur
the wironeless connection is cnected but when i want to browse pages, it says : " Web: No gateway reply"
i cant do anything which needed internet connection
anyone know how to solve this problem?
my comp spec is window xp sp2, D-Link wirelessADSL2+Router
You don't say what type of encryption you have on your router. I'm guessing it will be WPA or WPA2. I also had that gateway problem and only fixed it by changing my router to WEP. Give that a try and see how you get on
