Hello,
I want to learn that if it's (it SHOULD be technically) possible to have some of the N95 8GB properties on N95? For example, 7 links on standby instead of 6. Better UI font. I know, they are designed for larger screen but I'm O.K. for that, at least, it's the same resolution. Is it possible via a firmware change, or changing something with ROMPatcher etc.? Is there a way to install the 8GB (or other phone) firmware on original N95 (and make it work)?
Thanks,
Can.
