6680 without OS
6 replies · 7,110 views · Started 09 February 2009
Hello,
While I was updating my nokia 6680, my computer decided to turn off (Blue Screen in fact).
So, I now have de 6680 without any OS.
He doesn't turn on any more. When I try to make an other update, the logiciel find the phone, try to fix it, but he can't do anything.
Have you any idea ?
Is it possible to fixe it my self, or have I to spend money ?
Thx
LeNouveau
Take it to your nearest Nokia authorized repair center. Whether you need to spend money on getting it fixed depends on what kind of an agreement you can make with the repair center (the 6680 is such an old model that it is presumably out of warranty, but that depends of course on when it was bought from a retailer or operator and in which country).
Of course, my 6680 is not any more under warranty.
Apparently, I have no choice and have to pay.
It is between 30� and 60� :s
Thank you all the same.
LeNouveau
my phone is nokia 6680.how can i restore my unlock code?
can u calculate it for me plzzzz!!!
my imei is:355664000956478
I own the N6630. My n6630 almost sounds identical,.... that is if you do not screw with default EQ settings and junk. The only thing that makes a MP# player better then any nokia phone is the use of any headphones you want. With nokia phones you are restricted with the headset it comes with (but its still very good considering). - Or you can search the net for better aftermarket headphones for nokia. All that said, nokia mp3 quality on 6630-80-81 is very good. (take it from me, im a dance music producer so I know a thing or 2). The 6680 has identical sound quality to 6630. I wouldnt let MP3 playing be a factor in your buying. Choose a phone baised on the functionality differences. There is other non-nokia phones that kick ass when it comes to sound quality. Motorola has one phone thats amaizing, but I personally would not scrifice the symbian os for it.
I would like to use the 6681 as a device insted of Mobile to program the ARM processor.
Pls help
Reply sooon
I wouldnt let MP3 playing be a factor in your buying. Choose a phone baised on the functionality differences. 😃
