The best twitter client for E71?
7 replies · 39,470 views · Started 15 February 2009
At the moment, dabr is the best, however, there is a dedicated S60twitter client under developement, and should be available in the next couple of months.
You may try the free @SociallyApp (http://bit.ly/6mFra0) on Nokia phones. It supports Facebook, Twitter and LinkedIn and integrates with the phone book by showing the profile photos and latest status of the callers during incoming calls. Here�s a review � http://blogs.nokia.com/dailyapp/2010/02/socially-can-tell-you-whats-up-before-answering-the-phone/
smapdi wrote:Twibble is a good client that I've been using since I got into twitter several months ago. It does not use SMS but posts via your data plan.
http://www.twibble.de/
It has to be Gravity. www.mobileways.de. It's been well-documented here and elsewhere. Although you do have to pay a small fee, it's worth it for the quality of the interface and ease of use. I would say that in many ways it even rivals the mighty Tweetdeck.
great thread resurrection but a good question all the same 😉
Gravity is good for sure.... Nimbuzz's free client tho looks a lot like gravity in some respects and has a similar feel to it (tho it isnt anywhere near as good on the config side) tho you do get the added bonus of a load of bundled chat clients.
ELgambino wrote:Hello,
What is the best Twitter client for E71?
If you haven't already seen the comprehensive AAS review of twitter clients it can be found <here>
After that it really all depends on what features you're looking for, and whether you're more of a 'reader' than a 'poster' ..
I've used Dabr, TweetS60lite, and (more recently) Snaptu
Many are free to try so the best thing is to check the feature lists and then give them a go
Good luck!
Edit :redface: Just realised how old this original post was Feb-09 !
