Hello, I'm having a problem with the wi-fi of the N85 - it keeps disconnecting every 1 or 2 minutes. 😡Then it stops detecting the network for a while, although I'm sure the connection is present. Any ideas why this happens?:con?
N85 wireless problem
Make sure you're in close range to the wireless network you want to connect to. Also have a look in the settings for the WLAN wizard, it's quite helpful and lets you set things such as WLAN scanning to help you find wireless networks near to you.
