Hello everyone,
I'm just wondering if there is any application, except GooSync, although the full version is ok, I don't like it to use; so, is there any application free. I used GooSync but not all of the meetings from my Gmail calendar are sync with my phone, so I don't see any point in continuing to use the free version of GooSync.
I've also searched on the Nokia webpage but nothing
Can you sync your Google calendar to Outlook - and thus move it into the phone?
There's CalSyncS60, but it didn't work reliably for me - cant remember what the issue was though
http://s60addons.com/calsync/
chucky.egg wrote:There's CalSyncS60, but it didn't work reliably for me - cant remember what the issue was though
Ive tried to install the CalSyncS60 application but I am receiving an error message concerning the certificate. I've tried to do it several times, with the same result. I don't know if anyone was able to install the application on Nokia E51, and if they did maybe they can tell us how they succeed.
skagen wrote:Can you sync your Google calendar to Outlook - and thus move it into the phone?
I can try, but the thing is that it will muck easier for me do be able to do it directly from my phone, because is a kind of inconvenient for me to do that because, I have Outlook configured Outlook on my personal pc - and it is configured only for the Calendar things.
For those who need the Gcalsync, I found the application, I�ve downloaded, but to be honest I am not satisfy with the application. You will notice that the same meetings or memos you will have on the phone several times, which is not ok.
The below link will provide you the application, if you want it to try.
http://www.gcalsync.com/unsigned/gcalsync.jar
Try http://www.syncme.se/, it might be just what you are looking for. It's very easy to use and their free service has very few limitations compared to e.g. GooSync.
