hi,
i am having trouble with my mmconverter. i have no problems converting mp3 to wav but from mpg to nim i keep getting
-internal error
-mmconverter has caused an error in acc.dll mmconverter will close now
-mmconverter has cuased an error in mfc42.dll, mmconverter will now close
does anyone have any ideas???
cheers...ET
Have you got the latest version (MM Converter Pro)?
If you are using XP, try running the application with a compatibility layer type thingie (you know what I mean? Go to the properties of the application's shortcut, click on 'Compatibility'😉 and that could fix it.
where do i get the latest mm converter pro???
is pro for program or professional?
cheers...ET
Professional - it's just a slightly more advanced version, available from http//www.nokia.com/phones/productsupport/9210/downloads.html
More advanced version my arse, its just as CRAP as the old video converter.
Nokia really do need to get there hands out of there arses and start to develop a video converter which actually convert's the clips into quality clipa not crap ones where the picture is all distorted!
Come sort it our Nokia!
I have a similar problem with the convertor. Can convert audio files, but not video file. Same error for both the version on CD and the pro version.
Any more suggestions on solving this? Any other converters available?
Chris
You CAN convert excellent quality clips with the multimedia converter pro. If you don't mind having large files.
Not for NIM, you can of course convert to RealPlayer files for the 9210 using the free RealProducerBasic from RealPlayer, links are on my site at www.n9210.co.uk
Saw this a while back. Got round it by changing file extensions - eg .mpg to .asf. Converter then seemed to recognise the file as video and convert to .nim. Sorry, but can't remember which extension worked best. I think it was .asf or.asg
Can you get a better framerate than the 3.5(slideshow) cause that's to slow to watch anything. That's why I prefer Nim.
