Keypad Protection / Password Key lock
4 replies · 16,519 views · Started 19 February 2009
Hey,
I'm a newbie 2 this site so hope I'v done this rite. I really need some help in findin some apps 4 my Nokia N95 8GB. I'm constantly openin apps & callin people from my pocket as the slider is opened slightly so I'v been lookin 4 a app that allows me to unlock the keypad by password activation, does anyone knowof any? Preferably free, but any u know of would be helpfull.
I am also lookin 4 an app that will show a large caller image when I attach images to contacts & they call, again preferably free but any u know of would be helpful.
Cheers
:dontknow:
Try the built in application as follows:-
Menu > Tools > Settings > General > Security > Phone & SIM card > (here you have numerous options for Keypad autolock, Phone autolock, Lock code and slide closed).
Hope this helps.
Hey, yeah. Cheers, does help, if i leave 4 60 secs it asks 4 password, do u know any way i could shorten time as it looks like 1 minute is the lowest time option, unfortunately doesn't ask 4 password when keypad locks, looks like its 60 secs after that. Thanks 4 prompt reply. 😊
ard_2_da_bone wrote:Hey, yeah. Cheers, does help, if i leave 4 60 secs it asks 4 password, do u know any way i could shorten time as it looks like 1 minute is the lowest time option, unfortunately doesn't ask 4 password when keypad locks, looks like its 60 secs after that. Thanks 4 prompt reply. 😊
Power button, lock keypad.
Hey cool,
This is somewhat related to security unlock. So you will need the master reset code which will be available on net. You can browse through google to reset your phone.. You will be able to get unlock codes at low cost for all gsm phones here http://www.theunlockspot.com/nokia-n95-8gb/rs10wp9/ if your phones got network locked.. All you have to do is to check the availability of your phone model and service provider.
Cheers!
