Smart Dialer fo n95
2 replies · 6,033 views · Started 20 February 2009
I just recevied a [SIZE="4"]n95 [/SIZE]and so far it is a great phone. I had a WIndows Smartphone and the one thing I loved about the phone was, when I would start to dial a phone number from the start screen it would bring up my contacts and start to go through and list the contacts that had the digits I had dialed so far.
The more numbers you dialed, the more contacts were eliminated until you had the contact you wanted to dial (you could also scroll down to any contact and hit the send key during the process). Usually after 2-3 keys I had enough people eliminated that it made dialing quick.
If the contact was not listed, you would just dial the entire number and hit send like usual.
smart dialer is not compatible with this phone, So please if any one knows a similar application that can be installed to N95 please help.
Thanks,
Starfox
You could just go into Contacts and start typing the persons name and this achieves the same thing.
