A company called Baracoda has made it so that you can use your Bluetooth Cellphone as a mouse for your PC!
Download the FREE trial here... it initially only works with previous Ericsson phones though (T68i, T68m, T68, T39).
If the link above doesn't work, the URL is:
http://www.baracoda.us/baracodactrl/index.html
Yes, it is a P800 forum.
But since the P800 is manufactured by Sony Ericsson, the same makers of the T68, T68i, T68m, and the T39... there is a connection.
This is the first release of this product - which means that later on, it will support other phones - which means they will be supporting newer models than those listed above, which are already several years old.
Secondly, many users in this forum have either owned the above listed models, or still do. It might be interesting for them to try it out, and have a taste of what might be in store for their P800 later on.
Finally, this forum also exists to provide news and updates to its members. This is news, as this technology allows you to use your cellphone in an extended capacity not initially covered by manufacturer's specs. If this technology proves feasible, then a whole new avenue of use is opened for our cell phones.
I hope this simple reply addresses the need to connect this news article to the Sony Ericsson P800.
