How do I turn off the auto-lock during calls?
5 replies · 7,425 views · Started 20 February 2009
Anyone know of a way to turn off the auto-lock on a call when the screen comes near a surface? I find it very annoying, especially when I ring a number that requires me to press numbers to proceed!
TIA
Which firmware version do you have? Unfortunately mine stopped doing that after I installed the new firmware update (v20)...
Does anyone know a way to get this feature back?!
That's strange, I have the older version and it is working fine for me. During a call, when I aproach the phone to my ear it locks but it don't get locked when controlling it with my hands.
I think that the sensor is near the front camera. Try to leave that part of the phone clear when manipulating it.
I think I have worked out the problem - I have mine a Krussel case which seems to be covering up the sensor, what a strange design defect! I'll look for a case which keeps the sensor clear!
thanks
dlrpsteve wrote:I think I have worked out the problem - I have mine a Krussel case which seems to be covering up the sensor, what a strange design defect! I'll look for a case which keeps the sensor clear!
thanks
I had exactly the same problem with the Krussel Orbit case for the 5800 and ended up sending the case back after a couple of days.
At the time I wasn't sure if it was just my case that had been mis-manufactured but if other people are having the same problem it looks like Krussel have messed up the design.
I'm still looking for a decent case or pouch for the 5800.
This one looks decent but isn't available till the end of March (not exactly what you could call a prompt release)
http://www.expansys.com/p.aspx?i=177459&partner=froogle
So if anyone else has any case suggestions I'm interested.
