Hello Everyone!
I have a chinese E71 (0568863), which unfortunately has many features disabled (Wlan 3G/UMTS ... :mad😊, and moreover does not have Italian language support.
Which is best product code to select for the change (I'd like to maintain chinese language support anyway:con??)
Will I get back all this features?
Many thanks for your help! 😊😊😊
E71: which product code to choose?
Unfortunately you cant get some of the functions you want, cuz chinese E71 had removed the WIFI module, Wlan module. So it's the problem of hardware but not the software, whatever the product code you choose, it does not work....on the problem of language, I cant figure out which one can both support the chinese and italian...sorry about that
