Is this possible?
There must be a simple cheap nokia phone that uses the 1900 mhz gsm radio that is in the 9290. The phone section is simple isn't it?
I can take it apart I just need to know which phone to get for the donor radio.
Anyone know what that would be? Or a part number? If you own a 9290, would you be willing to find out the part number for the 1900 mhz gsm radio?
Obviously it would be easier to just buy a 9290 but that is impossible. I can't find one.
I am in usa so the 9210 is useless as a phone.
