which pc suite u people recommend?
the n series pc suite 2.0 or the nokia pc suite 7.1?
does someone have a link where i can download the n serie pc suite 2.0 completely instead of the 8mb web installer? thx 😊
The Nseries PC Suite has been replaced/superceded by Ovi Suite.
In any case, I only use the "regular" Nokia PC Suite myself (at least until it is still available, and Ovi Suite does not take over it, too).
does anyone has a link to download the nokia ovi suite? not the web installer but the full download package.
thx!
full download package for n series 2.0 please..its around 300 mb..
thx 😊 i dont want to install the web installer first as i want to have the full package available to install it offline.. thx 😊
PC Suite 7.1 vs Nokia OVI Suite
Main difference is Contact and Message editors !!! With the help of Nokia PC Suite, you can edit your Contacts as well as you can send messages from pc when your phone is connected with the help of Nokia Communicatin Centre, which is not present as of now in Nokia NSeries/Nokia OVI Suite. This is the major difference.
Then some applications like Image Store, Nokia Music Manager and File Manager(phone browser) are there in normal Nokia PC Suite whereas, Nokia OVI Suite has got stand alone applications like Nokia Music(replacement for Music manager in Nokia PC Suite), Home Media Server, Nokia Photos(Replacement for Nokia Lifeblog), etc are present in Nokia OVI Suite.
Applications like NSeries Music Manager and NSeries Video Manager were not there in Nokia OVI Suite. NSeries PC Suite was almost replaced by Nokia OVI Suite nowadays !!!!
Apart from this you can download stand alone applications like Nokia Map Loader, Nokia Software Updater(it will download along with both Nokia PC Suite as well as Nokia OVI Suite while installing), Nokia photos ....
Applications like Content Copier, Nokia Application Installer, Nokia PC Sync are common to both Nokia PC Suite and Nokia OVI Suite.
When it comes to user perspective, they feel Nokia PC Sync is much easier to use than Nokia OVI Suite's sync
you can install Nokia OVI Suite from the following site
http://www.ovi.com/services/support/nokiaovisuite
you can install Nokia PC Suite 7.1.18.0 from the following site
nokia.com/pcsuite
Good News is that you can install both the PC Suites on your pc without any problem, so that you can enjoy the facilities of both the PC Suites :icon14:
Have a great life 😊
