Has anyone found or can recommend any themes which take advantage of FP2.
Tried the usual places but nothing is really up to scratch - I'm looking for something as good as the Haze theme which comes installed on the N85.
Do you mean the FP2 Transitions?
AFAIK they don't differ with different themes. The transitions are biult into the firmware.
But... i have seen a hack using ROM Patcher to use other transitions.
(see Symbian-Freak forums for hack)
They seem to differ... a bit. The Nseries themes (and everything else I've tried) make the icons 'bounce' when highlighted but with the Haze theme they're surrounded by a swirly, sparkley thing.
I'll check out the forums on Symbian Freak, thanks for the advice 😊
Has anyone else turned on the "theme effects"? They give you transitions between menu functions etc.
car_guy143 wrote:Has anyone else turned on the "theme effects"? They give you transitions between menu functions etc.
thats what i was on about in my post.
I have yet to find anything that even comes close to spyronb by babi.
The absolute best I've found for my n78.
